QUOTE (95celicastLSR @ Jun 30, 2008 - 6:37 PM)
QUOTE (GTSOwner @ Jun 30, 2008 - 7:12 PM)
Unplug the wastegate actuator and weld the flapper shut.
all the wastegate stuff has allready been taken off...thnx
hi lance , whats up . all you have to do is get a flange with the hole blocked off and then you can run a external wastegate , make sure to get a gasket with it as well . if you need any help just call
