QUOTE (lagos @ Jul 8, 2008 - 1:49 PM)
you have a clutch related problem, probably from improper install.
i dropped down the tranny twice and double cheked the clutch i even had a mechanic to check out.
QUOTE (bccentaur3 @ Jul 8, 2008 - 3:31 PM)
Either that or you decided to use the gt-four shifter fork with the 3s throw out bearing on your s54 trans. Can you hear a loud bearing noise when you turn the car on? It will sound like a roller skate going really really fast. If this is the case drop your tranny and use the s54 shifter fork. I think you can keep the throw out bearing because the 3s and 5s have the same throw out bearings just different clips holding onto the fork. Well thats from what I was told.
yeah i was first using the 5s fork then switch the fork to 3s then back to 5s and still the gears wont go in
