QUOTE (mariosdarkworld @ Jul 18, 2008 - 12:10 AM)
What it even be worth the money or trouble of puttin a fmic on my car without the use of having a turbo or is it pointless cause i was thinkin it would be
There is a way to make it work on NA car.
If you use the W2A IC and using chilled liquid (lower temp then ambient temp) to remove heat it will work, and it will work as long as the liquid is chilled (using dry ice...etc)
But does the hp gain worth all the complication?
