MrBubbles
Jul 21, 2008 - 7:36 PM
sup people i just got done boosting my 5sfe, i replaced the rods and pistons w/ afteramrket parts and it's built to handle the turbo. i'm having trouble keeping my head gasket from leaking. i've replaced it twice and its getting annoying. can anyone point me to a head gasket thats better then stock... i cant find any aftermarket ones for turbo....
rjbibeau
Jul 21, 2008 - 9:15 PM
did you get your head machined so it's flat?
Jul 21, 2008 - 10:39 PM
is an OEM metal head gasket ?
MrBubbles
Jul 22, 2008 - 1:11 PM
yea everything was done right with the head and the block. i just cant find a head gasket made for boosted 5sfe. Only aftermarket one i could find was a metal one.
Jul 22, 2008 - 2:20 PM
are you using a metal headgasket ? or an aftermarket one ?
toyota makes a mhg for the 98-99 5sfe. that's your best choice.
MrBubbles
Jul 23, 2008 - 3:26 AM
on my 3rd oem metal head gasket.
jcaron9gt4
Jul 23, 2008 - 9:24 AM
your head is probably warped. An oem metal headgasket should not leak like that. Did you have your head resurfaced while you were getting work done?
Dr_Tweak
Jul 23, 2008 - 9:42 AM
Yeah definitely sounds like there's a problem with the head or the block not being perfectly flat, or the head is not being installed correctly. The stock head gasket should hold up no problem, that's not really a big problem spot on those engines.
That said, if you're running extremely high boost and you're still loosing the head gasket, you could o-ring the block.
-Doc
MrBubbles
Jul 23, 2008 - 6:44 PM
yea..... the shop ****ed up the head on it... wasnt assembled right (which they told me it was ready and done), and it was warped a bit (their fault) they took it apart today and they where shocked to see how bad it was. least their putting a new head on it for free.... so they say.
