Nyczroflz
Jul 26, 2008 - 3:16 PM
Jul 26, 2008 - 3:57 PM
Spider77
Jul 26, 2008 - 4:54 PM
Im not sure what kind of protection cardboard and foil would produce vs heat. Although its very creative way of going about it, I wouldnt pop the hood anytime soon. You could always get some sheet metal, and some tin snips, cut out what you need and have someone weld/grind/rivet it for you probly for next to nothing. BTW, is that clothes hanger wire holding together some stuff? If you need zip ties I'll give you some.
manphibian
Jul 26, 2008 - 5:02 PM
hmmm, not convinced by that one.
From what i've found from sri heat shields in practice;
unrestricted access to warm air > restricted access to very very slightly cooler air.
Spider77
Jul 26, 2008 - 5:05 PM
In theory thoug, could you help by brining some cold air in where the org ducting is? I think thats why the dryer hose maybe there. One more thing, is that tin foil in place of a fuse?
delusionz
Jul 26, 2008 - 6:19 PM
those home made dodgys aye... 100% function 0% look............if the aim is to have a big heat soaking air restrictor infront of the intake by all means go for it...
and the so called cold air feed is doing nothing at all from the stock location
Nyczroflz
Jul 26, 2008 - 6:35 PM
hmm ok i guess ill take it off then since it prob would do more harm than good.. thx for the feedback guys =)
