JDcelica
Jul 28, 2008 - 7:33 PM
I cant boost any thing over 4000 rpms. The engine just kinda dies and loses all power.
CelicaST_CALI
Jul 28, 2008 - 7:40 PM
do a compression test...
Jul 28, 2008 - 9:29 PM
You need to tune the car... and even then, welcome to the 5sfTe.
bccentaur3
Jul 28, 2008 - 9:36 PM
did you upgrade your spark plugs? And yeah Lagos is right and tune is needed.
FunkySR
Jul 29, 2008 - 1:17 PM
all in the mapping my friend.
JDcelica
Jul 29, 2008 - 4:51 PM
i put ngk plugs and wires. i still need to find a tune shop near me. compression is good.
devilsden97
Jul 29, 2008 - 4:54 PM
QUOTE (JDcelica @ Jul 29, 2008 - 5:51 PM)
gapped to? whats the part# from NGK
bccentaur3
Jul 29, 2008 - 4:56 PM
yeah you should gap them to .030, I think you are just running pig rich. You aren't supposed to push the motor that hard without a tune anyway. How much psi are you running?
JDcelica
Jul 29, 2008 - 5:06 PM
hard to say the boost gage is off by a little it says 6psi. if it helps i did not touch any of the setting on the boost controller.
JDcelica
Jul 29, 2008 - 5:11 PM
ill check the gap. should i do any thing with the timing if not were should it be at.
bccentaur3
Jul 29, 2008 - 5:12 PM
good, because I turned that thing all the way down. I basically let the turbo boost from the wastegate spring. I think you are just running really rich. Any backfire?
JDcelica
Jul 29, 2008 - 5:14 PM
it blows flames time to time.
Jul 29, 2008 - 5:20 PM
you are choking on fuel from not being tuned.
period.
/ thread.
