hey all.
ok AEM FIC fitted today. Wired everything up OK, but i have a feeling there is a problem with my MAP sensor. Here are the problems i'm facing at the minute. I'm still running the SAFC 2, but on the datafile 2 with all values set to 0.
1. CEL - Code 31. MAP sensor. Only on when FIC connected. I suspect connected wrong way round. If bypassed, there is no CEL.
2. With FIC bypassed, SAFC back to old map settings and driving along, it just cuts out after a few minutes. WTF??
3. I connected my crank position sensor as MAG (magnetic type) using pins G1 and G- (E5-5 and E5-18).
4. The 7AFE injectors seem to be batch ie signals to injectors 1 and 3 and same for 2 and 4. So I joined 1 and 3, and 2 and 4 on the AEM harness. That seemed to work.
5. I did not notice a camshaft position sensor. I went through the ECU pin oit like 50 times.
Where have i gone wrong and why is the car cutting out with no CEL.
Help please.
PS here are links to the pinoits..
http://www.emanageforums.com/forums/attach...mp;d=1206491637http://www.emanageforums.com/forums/attach...mp;d=1206491691I also cross referenced with this
http://evilspeed.com/SAFC.htmCheers
J
