bringindaheat573
Aug 15, 2008 - 7:58 AM
http://www.horsepowerfreaks.com/partdetail...ollers/FCD/1917 hey guys i was wondering if this was safe to use with a greddy e-manage ultimate and some larger injectors prolly sard 800cc with a tune to get some more power out of my 2nd gen 3S-GTE swap i have going in progress right now ?
Aug 15, 2008 - 10:43 AM
Yes.
But what turbo are you planning to use that would require 800cc injectors?
Have you read the power primer?
http://www.mrcontrols.com/primers/power.htm
bringindaheat573
Aug 15, 2008 - 2:27 PM
Well i was thinking maybe stock Fuel injectors wouldnt be enough if i wanted to use this and go above the 15 psi fuel cut im pretty sure it is. Reading this makes me learn alot of new things. And i was just planning to use my same old stock Ct-26 thanks alot for opening this information to me lagos.
Aug 15, 2008 - 2:53 PM
Stock injectors are perfect for any boost level the ct26 can make. You would actually be doing yourself more harm then good by upgrading them.
The power primer is a great way to learn the basic upgrade path for these motors.
