QUOTE (Smaay @ Aug 20, 2008 - 12:22 PM)
Thanks Manny for all your input, for this simple of a setup and only 7-8 psi the S-AFC will do the job. with the stock ECU pull timing when knock is detected?
yup. it works quite well for a low boost setup.
one thing tho.. if your only planning on running 7-8psi, those injectors are gonna be WAY big. somthing like 360-90cc's would be much easier to control, and get you better gas milage cruising.
IIRC dustin (batman722) had picked up a set, i cant remember what they are from, but IIRC they were like 390cc or somthing, but he sold them when he sold his turbo stuff.
