white97
Aug 25, 2008 - 7:11 PM
okay so i got the 4a in with the right throttle cable but my question is, does anyone know why theres a little bit of a delay with the throttle?
GriffGirl
Aug 25, 2008 - 7:38 PM
Sticking, IDK what it's actually called, but that round metal flappy valve thing that opens up on the TB when you accelerate. It can get pretty gunky over time and built up with carbon, which can cause it to stick. If you remove your TB and clean it thoroughly (being mindful of the plastic sensors, of course) you may notice a nice difference in throttle response.
Also, be sure your cap, rotor, plugs, wires and air filter are not worn down/dirty. These will also delay throttle response.
white97
Aug 25, 2008 - 11:10 PM
im not sure i had another post about whether i needed to upgrade the fuel pump from the stock 7afe one but the guys told me it'd be fine to run the stock one. i was thinking that might be, almost like its not getting enough pressure. it might be that i havent driven it in a while and it may just need to let the fuel thats been sitting in it run through again im really not sure.
