QUOTE (j0ch0a94ST @ Sep 12, 2008 - 1:52 PM)
i've been having some slippage issues with my 94st...i was curious if anyone knew if the 4age transmission would bolt up directly to my 7afe? would there be any issues that i should take into consideration before attempting the swap? thanks
It should bolt up as long as your not using the 4age transmission off the MR2s where the shifters are reversed. Use all bolts and mounts off your old tranny. Clutch, flywheel and everything else is the same on the 4age.
