QUOTE (Dr_Tweak @ Oct 9, 2008 - 2:30 AM)
Well uh, most of the time my impact takes it off no problem, if it won't work for you, then one thing you can do is (after removing the transmission and flywheel), thread in two of the flywheel bolts, opposite each other, and put a prybar between them, hold that with one hand while you work the breaker bar with the other, that way the crank doesn't spin. Or you may be able to wedge the prybar on something so you can use both hands on the breaker bar.
I'm assuming of course that the engine is out of the car.
-Doc
thanks for the advice doc, you will surely end up doing some wiring for me at some point. ha
and well some new information as of recent as well...
went to autozone, they told me just to break the bolt sealant loose required an impact wrench w/ a ridiculously high PSI (and the compressor to match). now luckily i know a guy who would probably take 2minutes w/the impact wrench at the nissan dealership he works at to give it a quick go. (any legitimate mechanic [no offense to anyone not in this situation who considers themself 'pro'] should have a compressor capable of 1,000+ psi) again, so the guy at autozone says...
and yes the engine is infact out of the car.
