This is what I have done so far. I still have to fab up a downpipe and figure out how to make a IC piping for the snailshell to the intercooler.
ok first picture if you look closely you can see i had to trim my fan haha & im worried cause i only have like about half a inch from the clutch clyinder bleeder valve..
showing off the heat shield i had to fab up to make work
showing how i did the oil feed line and the turbo..i love it!!
third gen block fitting
the real street tunning waste gate and the turbo adapter that muggs let me borrow..it looks good i think
the other side of the wastegate and if you look really close you can see i had to trim the heat shield for it to work
more pictures of the getto rigged fan and how close the turbo sits to the fan and raditor
and my bueaty with the front mount infront haha
ooh muggs i sand blasted the downpipe and painted it with high temp paint over all it looks good but i wont be able to use it cause it doesnt match up with my exhaust so the car will be taken to map performance for a new downpipe..
