QUOTE (Decalsondemand @ Nov 14, 2008 - 8:47 AM)
hi just wondering if anyone has detailed infor on removing the engine from my 94 gt?? it has a mt 5sfe any info regarding thing would be wonderful!! thanks
disconnect everything (fuel lines, shifter calbes, clutch line, axles..ect)
set up your engine hoist, remove the front to back crossmember, attach hoist to engien, remove passanger and driver motor mounts, and pull the motor and tranny together.
you will need to angle to motor to get it out. i normally use a chain attached to the hoist with ~16 chain links on the passanger side engine hook, and ~5 on the drivers.
lower the tranny, then pull it out on an angle.
