QUOTE (RabidTRD @ Apr 23, 2012 - 5:40 PM)
QUOTE (Promasta @ Apr 22, 2012 - 4:06 PM)
So will an auto camry throttle body work on the celica gt?
Yes if it's the same year as the Celica. OBD1 and OBD2 will be different as the EGR. Auto doesn't have two cables... any Celica/Camry will have two cables if there is cruse control. Gaskets are the same... everything matches up. In fact, I think even the air box is the same lol. Only place it differs is in the hose from the box to the intake (last I checked).
The auto does have two cables going to the TB. One goes to the gas pedal and the other goes inside the transmission.
For the cruise control, that cable actually goes to the gas pedal.
So on an auto 5s with cruise control, there are three cables altogether.
Since my swap, I still have the auto TB. The only difference from the auto to manual TB's is that the connection for the throttle cable on the Auto has two cable mounts / connections, where as the manual only has one cable mount / connection.
