BrandonToyota
Mar 5, 2009 - 8:53 PM
I have recently been having problems with my ECU-IG fuse poping and need some help. I have a 99 celica with the 4th gen 3sgte swap that i completed last year. The car keeps blowing the fuse in the fuse panel inside the car. I don't even really know what the fuse does or how to go about troubleshooting the problem. If anyone has any insight please help! Thanks
bccentaur3
Mar 5, 2009 - 9:00 PM
Is it the AM2 Fuse? 30amp fuse IIRC.
BrandonToyota
Mar 5, 2009 - 9:23 PM
QUOTE (bccentaur3 @ Mar 5, 2009 - 10:00 PM)
no it's the 15 amp fuse furthest t to the left in the row with only 2 fuses, the panel said "ECU-IG"
bccentaur3
Mar 5, 2009 - 9:38 PM
ahhh the efi fuse I would assume. You don't have any wires cut that are touching eachother? Is the fuse blowing when you try to start the car?
BrandonToyota
Mar 5, 2009 - 9:45 PM
QUOTE (bccentaur3 @ Mar 5, 2009 - 10:38 PM)
yes the fuse blows as soon as you go to the on position, but no cut wires are under there, i pulled apart all my interior plastics looking for something out of place and no wires were messed up. the most recent work i had done was a viper alarm system installed about 4 months ago by 6th avenue electronics. and i checked all the work and wires the guy spliced into and it all seemed fine.
bccentaur3
Mar 5, 2009 - 9:48 PM
Who did your wiring harness? How long have you had your swap?
BrandonToyota
Mar 5, 2009 - 9:54 PM
QUOTE (bccentaur3 @ Mar 5, 2009 - 9:48 PM)
Dr. Tweak at Pheonix Tuning in Savanah, GA. He specializes in them and i havn't had any problems with it. I finished the swap just over a year ago, i got the car running and back on the road Jan. 2008. It's my daily driver and I did all the work myself.
bccentaur3
Mar 5, 2009 - 9:57 PM
Well if Doc did it, theres no issues with his conversion. Did this just happen recently?
WOW!!! I just read that the fuse inside the car is popping not the one in the engine bay. Do you have a turbo timer?
BrandonToyota
Mar 5, 2009 - 10:44 PM
QUOTE (bccentaur3 @ Mar 5, 2009 - 9:57 PM)
yea it's the one inside the car. i had a turbo timer but i took it out.
bccentaur3
Mar 5, 2009 - 10:56 PM
was it hard wired into the ignition wires? Or was it plugged in with a harness?
BrandonToyota
Mar 5, 2009 - 10:57 PM
QUOTE (bccentaur3 @ Mar 5, 2009 - 11:56 PM)
it was hard wired in.
bccentaur3
Mar 5, 2009 - 11:01 PM
check the wires in there to see if there is any of it exposed and touching one another. Maybe some of the electrical tape got loose.
BrandonToyota
Mar 5, 2009 - 11:15 PM
QUOTE (bccentaur3 @ Mar 6, 2009 - 12:01 AM)
ok ill deff check again. it's been really cold out so i havn't been working out there too much. thanks do you by any chance know what that fuse protects?
bccentaur3
Mar 5, 2009 - 11:29 PM
Sorry I don't. I would assume to keep the ecu from popping. I really don't know.
stephen_lee
Mar 5, 2009 - 11:40 PM
i'll have a look at the diagrams and ill reply what it protects and where i think there may be problems
BrandonToyota
Mar 5, 2009 - 11:43 PM
QUOTE (stephen_lee @ Mar 6, 2009 - 12:40 AM)
Ok, Thank you
stephen_lee
Mar 5, 2009 - 11:55 PM
power flows:
battery>main fusable link>100A alt>40A AM1>IGN switch>15A ECU-IG
Circuits Protected:
A/C pressure switch
ABS ECU(antilock brakes)
Cruise Control ECU
Shift Lock ECU(auto only)
Water Temp Switch (for engine fans)
Engine Main Relay(coil side)
Fan Relays 1 & 2 (coil sides)
Odd thing is, the engine control unit really doesnt get power from this fuse* lol
I'll reply again in a bit after i look for probable issues
*edit, put switch by accident
BrandonToyota
Mar 5, 2009 - 11:58 PM
QUOTE (stephen_lee @ Mar 6, 2009 - 12:55 AM)
power flows:
Circuits Protected:
A/C pressure switch
Cruise Control ECU
wow who would have thought!! thanks so much i appreciate it, the thing was driving me crazy
stephen_lee
Mar 6, 2009 - 12:49 AM
I'd really check those wires the turbo timer was wired into. though i don't think thats where the problem is since its 'upstream' of the fuse (it'd be blowing AM1)
