QUOTE (ksporry @ Jul 1, 2009 - 1:49 AM)
Sorry, I'd like to use this as a guide to replace my clutch plates, so I have a few questions:
1) Is it really necessary to remove the engine mounts to drop the tranny?
2) If you do that, shouldn't you first support the engine and the tranny before you remove the mounts?
3) Shouldn't you at least first support the tranny before undoing the tranny mount?
4) Is it possible to leave the engine mounts in place, support the tranny, undo teh tranny mount bolts and then lower the tranny?
yups like what everyone said
1.Yes front and rear
2.No like Presure2(Manny) said both right and left side engine mounts hold the engine and tranny while the front and rear mounts are out.
3. Yes put a wooden block between the oil pan and jack and support the engine. Then use a engine crane/cherry picker/transmission jack to support the transmission. Then remove the driver's side trans mount.
4. No you need to remove the front and rear engine mounts to get to the trans bolts and to lower the engine enough so you can slide out the trans. MAKE SURE YOU LOWER THE ENGINE ACCORDINGLY BECAUSE OF ALL THE WIRING AND YOUR EXHAUST.
QUOTE (presure2 @ Jul 1, 2009 - 6:25 AM)
QUOTE (dgbldr @ Jul 1, 2009 - 11:17 AM)
Once you get to that point, where the engine and trans are lowered and separated, is there enough room to replace the clutch without taking the trans out?
you dont have a choice but to pull the tranny off to replace the clutch.
He has spoken
QUOTE (lagos @ Jul 1, 2009 - 7:02 AM)
QUOTE (808celica @ Jul 1, 2009 - 6:25 AM)
QUOTE (lagos @ Jun 30, 2009 - 5:32 PM)
VERY COOL!
btw, you dont need to remove your hubs or your tie rods. you can just unbolt the top two suspension bolts, and swing the whole assembly out of the way.
yeah that was my other option but i dont wanna mess with my camber
it wont make a difference on the camber. camber is controlled by the two 19mm bolts that are connected to the strut. our cars have very little room for adjustment from those bolts, and you can simply push or pull the hub to/away from you to kick the camber out a little when you bolt everything back up. no negative impact to swinging that hub out, just less work.
Ahhh okay thanks Art. I've been doing my way for soo long
its like second nature already.
Well i might as well remove my struts to put on my ebay coils cuz the 18's will go on for advertisement
