QUOTE (Bitter @ Jun 30, 2009 - 7:27 AM)
no, check timing with a timing light correctly, theres a how-to.
TPS could be a loose throttle cable or crap below your gas pedal.
X2
verify the throttle is opening 100% by having someone step on the gas, while you watch the TB.
watch the throttle plate open as they press the gas, then once its floored make sure you cant open the throttle any more using the throttle wheel on the TB itself.
