QUOTE (Bitter @ Jul 2, 2009 - 9:48 PM)
if they are TTY then yes, check the torque spec, if its a lb/ft and then turn 90deg or some degrees then they need to be replaced.
Always replace hardware like that when u start ripping things apart!
The more you can do while the block is apart the better for future, and most of it is not expensive at ALL
