97celicaca
Oct 21, 2003 - 7:27 PM
are all air intakes pretty much the same? like those APC ones you always find @ autozone etc. are they crappy or what? also is it hard to install an air intake? or do i need a pro?
FallenHero
Oct 21, 2003 - 9:59 PM
I installed my first intake in about 15 minutes if that tells you anything.
Jon
EDIT: oh, and a short ram is a short ram. Just get a good filter and you'll be good.
PlanetFuzz
Oct 21, 2003 - 10:01 PM
I have very minimal knowledge about cars and I did mine. I recommend the Injen one
nicksceli
Oct 22, 2003 - 5:23 PM
if your going with cold air brand will most likely make a small difference but if your going with a short ram air buy the cheap one and get a quality filter like k&n and you'll be good. i made my own intake with pvc and a k&n filter and am very pleased with the results. it sounds mean and is a little quicker accelerating.
97sccelica
Oct 22, 2003 - 5:40 PM
i have that same intake.
i had it on my car then i went turbo. im still using it but i had to modify it a bit.
initialdrift55
Oct 23, 2003 - 2:21 AM
Wut intake for the St do you recomend CAI or short ram and wut brand?
BigEdge169
Oct 23, 2003 - 2:56 AM
I've got an ST and I've had a short ram (if you want to call it that) for a while. All I did was take out the air box and I put a cone filter on the end on the plastic intake tube, it worked just fine and was very cheap.
I'm about to build a CAI (I'm waiting on parts) and I'll let you know if I notice any difference after this weekend.
You can make one relatively easily or Doleck Racing (http://www.evilspeed.com/cai.htm) makes a good one too.
