QUOTE (6gtfour @ Sep 18, 2009 - 9:15 PM)
Again let me start by saying I'm not and was not trying to bash the product!
I know you are not bashing, I hope you dont take my comments offensively
call me a bean counter but to me, from a consumer standpoint, a purchase is a purchase when the primary objective is horsepower. In that regard I'm not comparing apples to oranges I'm comparing dollars to dollars for the same horsepower result as given on a dyno. That was the entire point I was hoping to make by using that analogy.
Ok, I understand saving money while still achieving your desired HP levels. But, I still dont understand how you are using it in this situation. I will merely continue on your comparison of this kit to a set of cams.
Price was never spoke about, so we cant actually compare dollar for dollar yet, but yes...the cost of the cams THEMSELVES will be less this turbo kit I am sure. But there are a few things to remember.
1. No cam will you get an additional 80+whp (making out the factory GEN3 fuel system) like bolting on one of these turbos
2. You need to run an EMS (about 2000$ + tuning 5-800$ + the cost of the cams themselves 600$) when you swap out your factory cams for upgraded cams....where as you can get away with just slapping a larger turbo on your stock ECU as long as you keep boost within your fuel trims.
This is useful to you personally but to a wider range of perspective users of the same product many of which have little knowledge or experience like you do, and are half way around the world from you like i am, it offers very little by way of consistency(repeatable results). There is no way to know what condition each motor in the 5-10 setups you refer to were in at the time of testing therefore making it more difficult to someone purchasing a kit to repeat the same results.
If you can evaluate that the factory turbo performs to X peak value on an engine that has been blueprinted to manufacturer specifications, then you can evaluate that your upgrade turbo or turbo kit adds Y amount of power, and you have two immediate and considerable advantages.
1. a perspective customer anywhere in the world with little or no knowledge of tuning and upgrades can rest assured that under similar conditions your kit will provide a similar increase in power on an engine of the same rebuild status providing that the external and limiting factors are similar.
2. After sale support and warranty/guaranty issues become less sketchy as it should be quite clearcut that if a customer does not achieve similar performance figures that the turbo or kit is the least likely thing causing the problem.
Most vendors publish information in a manner that is misleading and sometimes completely useless to customers. It does not mean that we should endorse their shortcomings.
"having a few different dyno runs to compare -WHAT? - to"? your engine? who's to say that your engine is currently at the same spec as the one they used? and believe it or not even the manufacturer spec is not any real bullet proof sort of guaranty that you will get repeatable performance across the board between engines at that spec. Having to accept that inevitability, the best approach in my opinion is still being able to know the limit of the manufacturer spec which is fairly easily attainable and repeatable around the world.
I dont understand how having 10 dynos results on 10 different motors, all running the stock ECU with the same turbo is LESS consistent of results as ONE dyno that you would like to see achieved on a freshly built motor tuned for maximum hp.....? If this was an accepted way of advertising X hp for Y turbo, there would be A LOT of pissed off costumers out there when they Specifically bought Y turbo with intentions of running X hp at Z psi like the vendor had proclaimed for there street car. But the problem is, is they cant run 13.0-1 AFR's add GOBS of ignition advance on there street car like the vendor could get away with for a few dyno runs with race gas. And over time, the more people that bought Y turbo for X hp, would all hop on these forums and start comparing there ACTUALLY hp on there OWN motors....and the more people that send in there results....you start seeing consistent results. If 10 people post there dynos of the same turbo, on stock ECU (so same tune) with the same bolt ons...and there is a range of 10-30whp difference between each at Zpsi, it would mean that all 10 cars were in proper working condition.
And YOU as a potential customer
should KNOW the condition of health that your motor is in. After confirming that motor is in fact proper working healthy condition...you KNOW what kind of hp Y turbo will make at Z psi....as you have the same ECU, tune, and other bolt ons as the other members did.
Essentially my advice was based on the premise that depending on your approach in the development of your product the results or dyno results you are able to display can be of more use to perspective customers.
I dont think more useful, as I think misleading.
