it almost sounds like a worn out oxygen sensor or fuel pump. What is your stoichiometric reading during the hesitation. From what i can tell, it sounds like your engine is leaning out during full throttle when the engine begins to heat soak.
QUOTE (domyz @ Oct 4, 2009 - 7:41 PM)
7AFE isn't a race engine, you would do better with a S series engine like the 3SGE
It looks like spark plug overheating leading to detonation
try colder thermostat, hood air duct, insulate headers, colder grade spark plugs
The hesitation would not be caused by spark plug detonation because it only happens after heat soak. Once the engine is warmed up the spark plugs will remain the same temperature.
QUOTE (SwissFerdi @ Oct 4, 2009 - 8:53 PM)
I don't know about fuel cut, but redline is 5800.
red line is different on different year 7afe. It was higher in the older generation before obd2.
