upscaleauto
Oct 12, 2009 - 10:17 PM
Megan Racing Street Series Coilovers for 94-99 Toyota Celica FWD$850/set with Discount Code! Free Shipping (lower 48 states)! Brand New with Warranty!Simply enter code "6GCMRCDK" during checkout - follow the links below!Megan Racing Coil-Over Dampers are the ultimate upgrade to your track or street car. Featuring 32 Levels of damper force adjustment, full-height adjustment, these damper kits are then perfectly matched with front and rear Pillow Ball upper mounts for camber correction in most applications.
The adjustment of the damper is as simple as can be with a built-in knob at the top of the damper mount for easy access. Simple adjustments can be made to tune to your style of driving and comfort level desired. Single-Adjustable dampers make suspension adjustments easy to tune whether you're a professional mechanic or an automotive enthusiast with amateur mechanical skills.
The height adjustment is made easy with CNC-Machined locking perches for accuracy and smooth adjustment. You can raise your car up to factory height for OEM appearance with performance handling or you can drop your car all the way down for a formal racetrack and an aggressive stance lowering your center of gravity to gain full potential of your car's handling capabilities.
On most applications, the Megan Racing Damper Kits come with fully adjustable Pillow-Ball upper mounts to easily tune and adjust your camber. Adjustable camber gives you an edge on most suspension setups, as you can easily tune your car for any ride height which improves handling, predictability and furthermore tire wear, which is a great benefit both on the racetrack and on the street.
The quality and durability of the Megan Racing Damper kits are unmatched. Made of extremely durable Steel and featuring springs that are constructed of SAE-9254 Cold-Wound Steel which are then tested over 500,000 times by compression inspection. With deformation less than 5% and high strength sophisticated surface coating, Megan Racing stands by their product with a strong warranty.
Features:
Spring Rates: Front 10kg/Rear 8kg
32 Levels of Adjustable Damper
Pillow Ball Upper Mounts
Rubber Dust Covers
Adjustable Ride Height
Aggressive Spring Rates
Single-Cylinder Design
Aluminum Brackets
32 Levels of Adjustment:1-8: Suggested for track use
9-16: Suggested for mountain/aggressive use
17-32: Suggested for common street use
All coilover damper kits come with 1 year manufacture-defect warranty $850/set with Discount Code! Free Shipping (lower 48 states)! Brand New with Warranty!Simply enter code "6GCMRCDK" during checkout - follow the links below!Megan Racing Street Series Coilovers for 94-99 Toyota Celica GT/ST FWD
This group buy is now open and active to all members. We can accept payment directly via Paypal or through our website checkout. For website checkout, enter code "6GCMRCDK" to receive discount!Megan Racing Street Series Coilovers for 94-99 Toyota Celica GT/ST FWD
Megan Racing Street Series Coilovers for 00+ Toyota Celica
Megan Racing Street Series Coilovers for 89-93 Toyota Celica All-Trac
Megan Racing Street Series Coilovers for 90-93 Toyota Celica GT/GTS FWD
Megan Racing Street Series Coilovers for 93-98 Toyota Supra
Megan Racing Street Series Coilovers for 00+ Toyota MR2 Spyder
Megan Racing Street Series Coilovers for 91-95 Toyota MR2$850/set with Discount Code! Free Shipping (lower 48 states)! Brand New with Warranty!Simply enter code "6GCMRCDK" during checkout - follow the links above!Note to admins: Coomer has not responded to PM's. If there is another admin who needs to verify/approve this posting, please PM and let us know.
cjh4l22
Oct 12, 2009 - 10:37 PM
ahh if i were done with my swap i'd grab a set of these... damn. maybe next month.
BonzaiCelica
Oct 13, 2009 - 1:36 AM
how much longer will these deal be going on for??
808celica
Oct 13, 2009 - 3:35 AM
did you go through 6gc management to set up a group buy???
upscaleauto
Oct 13, 2009 - 4:27 AM
QUOTE (808celica @ Oct 13, 2009 - 4:35 AM)
As stated at the bottom of the original post we attempted to contact Coomer via PM as instructed in the forum rules, but did not receive any response. Coomer's last post on the forums looks to be August of this year, so we went ahead and posted the GB. Hopefully an admin will take a look over this thread send a PM over letting us know if anything needs to be changed about the GB. If you will refer us to someone other than Coomer who we can get in touch with about this GB, it would be much appreciated! Until we are able to get in touch with Coomer or another admin, please check out our 6GC profile including feedback and also feel free to contact Megan Racing to confirm that we are an official distributor in good standing.
QUOTE (BonzaiCelica @ Oct 13, 2009 - 2:36 AM)
We currently do not have a date set. It will be running through at least the end of October.
upscaleauto
Oct 13, 2009 - 4:33 AM
QUOTE (cjh4l22 @ Oct 12, 2009 - 11:37 PM)
We should be able to offer this into November. We have no definite date set yet.
upscaleauto
Oct 13, 2009 - 4:42 AM
These would be great with a swap. The car in the photo has a 5SFE, full exhaust, and HKS filter. The coilover upgrade alone made a world of difference. The difference will be even more significant in a higher powered Celica with a swap. Compared to other brands, the adjustability of these is amazing - 32 levels really is a large range! You can go from super stiff to super soft and anything in between. The stiffness adjustment along with the ride height adjustment and front pillowball camber plates really allows you to dial these coilovers in to the exact setup that will match your performance setup, wheels, body kit, etc. These are definitely worth keeping an eye on for when you finish the swap!
whatthe
Oct 13, 2009 - 5:33 AM
Interested, tho how much do you think shipping will be to Australia?
trdproven
Oct 13, 2009 - 10:24 AM
if this is upscaleauto the company, i bought directly from this company.
samir0189
Oct 13, 2009 - 11:08 AM
I purchased my megan springs from upscale auto, great company.
808celica
Oct 13, 2009 - 2:07 PM
QUOTE (trdproven @ Oct 13, 2009 - 5:24 AM)
you da first one with megans
whats the absolute max drop on these???
95CelicaST
Oct 13, 2009 - 2:09 PM
Low enough. I think he said he was at 3" or 3.5", you can probably do 4" no problem.
808celica
Oct 13, 2009 - 2:14 PM
hmmmm......
anyone else in on this??
upscaleauto
Oct 13, 2009 - 3:28 PM
QUOTE (whatthe @ Oct 13, 2009 - 6:33 AM)
Unfortunately, the box is really large and heavy, so shipping is really expensive in the $200+ range via FedEx. This package is so large that even if you ship USPS, they hand it over to FedEx to finish the job! Please let us know if you are still interested in a quote and we will be glad to get an exact price based on your full address, but we just wanted to provide warning of the cost range first!
QUOTE (trdproven @ Oct 13, 2009 - 11:24 AM)
QUOTE (samir0189 @ Oct 13, 2009 - 12:08 PM)
Thanks for the references guys!
upscaleauto
Oct 13, 2009 - 3:35 PM
QUOTE (95CelicaST @ Oct 13, 2009 - 3:09 PM)
We don't have exact numbers on this, but on the black Celica in the pictures, the drop was probably in the 3" range but could have gone lower if we had smaller diameter wheels/tires. Depending on your drop, you should strongly consider
Eibach Pro-Alignment Rear Camber Bolts for 90-99 Toyota Celica GT/ST FWD (exc. All-Trac).
TiGZ461
Oct 13, 2009 - 4:35 PM
Damn looking foward to this, if it goes 3 or lower, I'm sold
02bluerolla
Oct 13, 2009 - 4:49 PM
arghh damn it maybe next month for sure.
trdproven
Oct 13, 2009 - 5:01 PM
with how much adjustability left that I see on the threads, looks to be at least 4 or over inch drop.
upscaleauto
Oct 13, 2009 - 5:22 PM
QUOTE (02bluerolla @ Oct 13, 2009 - 5:49 PM)
We'll see what happens this month and go from there. Right now, there isn't any reason we shouldn't be able to offer this into November.
QUOTE (TiGZ461 @ Oct 13, 2009 - 5:35 PM)
Not sure what you mean by "3 or lower"? Explain and we'll see what we can do!
95CelicaST
Oct 13, 2009 - 5:28 PM
He means if it can go 3" drop or lower he's in.
Stambo
Oct 13, 2009 - 8:44 PM
Damn, if you guys do another group buy in the spring, i'm down for sure!
upscaleauto
Oct 13, 2009 - 10:23 PM
QUOTE (95CelicaST @ Oct 13, 2009 - 6:28 PM)
Ahh, well we can't change that, but it should definitely go 3" or lower. We have them set with lots of 'thread' to spare in the photos above and the car is still lower than the TEIN S Tech's that were on prior to the install.
From the center of the fender lip to the center of the hub, the measurement on the black car is right at about 13" in both the front and the back. If someone can take this same measurement on a stock Celica, we will be able to know exactly how much the black Celica is lowered in the photos. Please see below for more info on how much lower these coilovers can go than we even have them set!
Here are two comparative photos to help when making your decision.First photo shows pretty much the
lowest the coilovers will go - any lower and the threaded sleeve would start coming through the bottom of the lower mount. The second photo shows after height adjustment was set to the levels you see on the black Celica. Pictured with one set of Eibach camber bolts. We ended up installing another set in the lower knuckles in order to achieve maximum clearance and minimal negative camber for the 17x8 WRX offset wheels and 235 tires. If you are using Celica offset wheels that don't result in such a clearance issue, you can see that you will have
LOTS more lowering room than we used! Look at the difference in height between the two photos!
upscaleauto
Oct 15, 2009 - 4:04 PM
Still need those first 3 to join the GB!
upscaleauto
Oct 16, 2009 - 2:37 PM
Offer still valid, just waiting on a few members to take advantage of it! Let us know if there is anything else we can do, questions we can answer, etc!
whatthe
Oct 16, 2009 - 7:38 PM
QUOTE (upscaleauto @ Oct 14, 2009 - 7:28 AM)
Hey, ,im still interested. Quote would be great.
upscaleauto
Oct 16, 2009 - 10:16 PM
QUOTE (whatthe @ Oct 16, 2009 - 8:38 PM)
Please send your full shipping address over via PM and we will be glad to get an exact quote for you!
epocsirhc
Oct 16, 2009 - 11:17 PM
I might have to pick some of these up.
upscaleauto
Oct 17, 2009 - 12:34 AM
We just need 3 members to commit before we can post/activate the discount code!
TiGZ461
Oct 17, 2009 - 3:05 AM
If I had the money, I would so be down for this. Too bad I'm broke as can be, hopefully this is still going on when I get the cash.
epocsirhc
Oct 18, 2009 - 12:55 AM
I'm in, and hopefully two other people! Does this model come with the top mounts that allow the camber to be adjusted? Either way I am excited.
02bluerolla
Oct 18, 2009 - 1:12 AM
Im in but i will have the money till next month for sure
epocsirhc
Oct 18, 2009 - 1:34 AM
Un mas por favor
trdproven
Oct 18, 2009 - 6:26 AM
QUOTE (whatthe @ Oct 17, 2009 - 10:38 AM)
Pls give this guy a quote, haha its about time you got to this mod.
Anyways in the pic, why is the camber bolt set to give it negative camber by the inward facing tab? I believe facing the tab out corrects negative camber (by giving postive camber) unless you want negative.
whatthe
Oct 18, 2009 - 7:50 AM
QUOTE (trdproven @ Oct 18, 2009 - 10:26 PM)
You crack me up man haha. Yeh i got pmd a quote. Its either this or Bc coilovers.
upscaleauto
Oct 18, 2009 - 1:14 PM
QUOTE (epocsirhc @ Oct 18, 2009 - 1:55 AM)
This model has front upper camber adjustment plates. The rears are not camber adjustable, so we recommend the use of the
Eibach Pro-Alignment Rear Camber Bolts for 90-99 Toyota Celica GT/ST FWD (exc. All-Trac) if you need rear camber adjustment. We actually used two sets of these bolts in the black Celica pictured, but only one set in the upper knuckle bolt holes should do the trick in most cases.
Added you to the list in the original post! As soon as we have 2 more confirmed, we will publish the coupon code and payment can be made! Once the payment is received the coilovers will ship out!
QUOTE (02bluerolla @ Oct 18, 2009 - 2:12 AM)
Added to the list! Thanks!
QUOTE (whatthe @ Oct 18, 2009 - 8:50 AM)
Still waiting on a finalized/best rate. Hopefully it will be better than the preliminary quote we got through FedEx!
upscaleauto
Oct 18, 2009 - 1:20 PM
QUOTE (trdproven @ Oct 18, 2009 - 7:26 AM)
These bolts can be super confusing, there is a tab that goes into the actual hole as well as that outer tab. You can't see the inner tab once the bolts are installed. The inner tab is in the opposite orientation as the outer tab and lines up with the elliptical/cam area of the bolt. You really have to play with these bolts and tab orientations once you get them to make sure you are getting the adjustment you are looking for. The installation you see there is definitely providing positive camber adjustment. We installed the bottom set of bolts opposite the first and got some additional positive camber adjustment. Hope this helps explain a little bit better. Let me know if there is any more info I can provide that may help!
upscaleauto
Oct 22, 2009 - 6:55 PM
Come on guys, we need one more participant to kick this thing off!
Don't leave epocsirhc and 02bluerolla hanging!
upscaleauto
Oct 26, 2009 - 3:59 PM
To the top! One more person to get this going!
marco-polo
Oct 26, 2009 - 10:35 PM
if i had that money on hand i would jump on them!
Oct 29, 2009 - 3:08 PM
can i get a set for the ST185 All-Trac at this price?
upscaleauto
Oct 29, 2009 - 4:45 PM
QUOTE (Smaay @ Oct 29, 2009 - 4:08 PM)
Sure, we would be glad to help out with any of your Celica's, the MKIV Supra, and we can also cover MR2's! We can offer this deal on the following coilovers and if you'd like to purchase, that will make the 3rd required GB member to make this deal official!
nics
Oct 30, 2009 - 1:01 AM
are the struts rebuildable?
upscaleauto
Oct 30, 2009 - 3:27 PM
QUOTE (nics @ Oct 30, 2009 - 2:01 AM)
Not sure about this. If there were any issue(s) with these coilovers, Megan Racing would handle applicable issue(s) directly under their warranty program. For instance if a strut failed, it would likely be covered. Since every situation is different, we suggest contacting Jose at Megan Racing at 626-581-0988 to discuss your concern and see if it would be covered under warranty.
Stambo
Nov 1, 2009 - 11:15 AM
Are we sending payments right away or just seeing if we can get the discount first?
upscaleauto
Nov 1, 2009 - 3:20 PM
QUOTE (Stambo @ Nov 1, 2009 - 12:15 PM)
No payments required until we get at least 3 commitments. Once we get 3 commitments, we will post a discount code to be used through our website checkout to receive this discount. The code can then be used by all members. We just need those initial 3 commitments to get it going.
epocsirhc
Nov 1, 2009 - 11:00 PM
I am sorry to do this but you are going to need to remove my name from the list because I am selling my celica. I apologize to the other members who want this group buy to happen.
upscaleauto
Nov 2, 2009 - 12:51 AM
QUOTE (epocsirhc @ Nov 2, 2009 - 12:00 AM)
Understood, you have been removed form the list. sorry to hear you are letting the Celica go!
02bluerolla
Nov 2, 2009 - 12:03 PM
NOOOOOOOOO . Upscaleauto: can you pm the normal price incase the group buy doesn't happen.
upscaleauto
Nov 2, 2009 - 5:18 PM
QUOTE (02bluerolla @ Nov 2, 2009 - 1:03 PM)
No problem - we have gone ahead and made this GB offer active for everyone here at 6GC. No minimum order required anymore!
upscaleauto
Nov 12, 2009 - 12:10 AM
It's November 12th! Take advantage of this deal while we can still offer it! No one has cashed in on this offer yet and we still have coilovers in stock and ready to get out to you at this super-low price!
Offer good through this month only!
