you can put a breaker bar on it and crank the motor (pull the ecu fuse so it doesnt fire)
you can use a rattle gun
you can man up and use your guns
(arms incase you dont get that)
use an extension on your breaker bar if its needed.
also give the head of the bolt a few taps with a hammar to help it loosen.
