TerBeau
Nov 5, 2009 - 9:20 AM
i found 1988 prizm with a 1.6 litre and im assuming this can fit a trecel. but will this fit in my 96 celica? i didnt buy it yet. but the lady wasnt to sure if it was a 5afe or a 4afe. will this work in my car for now? oh and my 96 celica is the st no the gt so the wiring is for a 7afe.
Demios
Nov 5, 2009 - 9:27 AM
The 5A is a long stroke kit made from HKS for the 4A O.O did u mean 5S-FE?
TerBeau
Nov 5, 2009 - 9:31 AM
QUOTE (Demios @ Nov 5, 2009 - 10:27 AM)
haha opps yea. too much on my mind. i need this motor so i have a snow car for this winter. because i just got my 94 back from the body shop and dont want that getting all beat up. but you familiar with the 88 1.6?
Mstoochn
Nov 5, 2009 - 5:37 PM
yes the mounting of the 4a and 7a-fe are the same, i do believe you will need the wiring harness and ecu. fairly plug and play
is this a 4a-fe or 4a-ge? u may be able to use the same harness with the FE head
95CelicaST
Nov 5, 2009 - 6:43 PM
If I recall correctly, Aaron (Blakout16?) Was running a 4AFE on 7A wiring and ECU without a problem.
And your 7A transmission will bolt directly to the 4A motor. It's all the same.
TerBeau
Nov 5, 2009 - 7:34 PM
well thanks for all the input. i wen tto go look at this motor and so happens that he had a 7afe motor sittin under his work bench and bout that for 50 bucks haha. motor and trans great buy.. just needs the block plained and new head gasket.
