terbear4god4life
Jun 11, 2010 - 8:32 PM
anybody have a write up or anything to do it??
Jun 12, 2010 - 7:02 AM
bleeding the clutch is simple.
its done at the clutch slave cylinder, located at the front of the tranny, to the right of the exhaust manifold (look for the bleeder screw)
its an 8mm bleeder.
make sure the resivour is full, then have someone pump the pedal a bunch of times, then hold the pedal to the floor.
release the bleeder, squirt fluid everywhere, then tighten bleeder. repeat till the fluid is clean, and free of bubbles.
its a one man job with a mighty vac. (you can get one at your local autoparts store for ~30$.)
terbear4god4life
Jun 12, 2010 - 11:42 AM
alright sweet thanks..
i hate too ask this but were is the right resivour??
SleekCelica
Jun 12, 2010 - 11:58 AM
Its the reservoir closest to the diagnosis pin in the back part of the drivers side of engine bay. You should see two reservoirs, your brake, and a smaller one, your clutch.
terbear4god4life
Jun 12, 2010 - 12:45 PM
QUOTE (SleekCelica @ Jun 13, 2010 - 6:58 AM)
awesome thanks 6gc!
Jamchell
Jun 12, 2010 - 4:58 PM
Just a tip if you don't want fluid all over the place you can attach a clear plastic tube to the bleeder, which also helps you see the air bubbles coming out.
