Xvani
Jun 26, 2010 - 8:53 PM
I think I have an overheating problem.. Looking at gauges it looks fine, but it heats up pretty fast (about half way+) and EZlube pointed out that my coolant had rust.
When checking the levels of coolant, it looks like it's completely dry. Might have to add distilled water, as I don't know what it's supposed to look like.
On the fan though. Should it run if it's completely cold? Or does it only turn on once the engine is warm?
Thanks
Johnnyny
Jun 27, 2010 - 12:11 AM
its not always supossed to run
Jun 27, 2010 - 8:17 AM
bad coolant temp sensor possibly, try replacing the two wire one.
Xvani
Jun 27, 2010 - 6:33 PM
Thanks guys!
Do I add water to the plastic overflow reservoir on the right, or straight into the radiator where the metal cap is in the middle?
Jun 27, 2010 - 6:45 PM
if both are low, add to both.
Xvani
Jun 27, 2010 - 6:55 PM
waiiiit, there are TWO places to check? lol. I only know how to check the plastic one!
Jun 27, 2010 - 7:17 PM
...you just asked which of the 2 to add to so you obviously know there are two places.
Xvani
Jun 27, 2010 - 7:50 PM
Not where to check the LEVEL of the middle one.. Only the plastic one
blu94gt
Jun 28, 2010 - 11:49 AM
I always add water straight to the radiator.
The fan will run more when it's hot out and you're going slow or stopped, especially if your A/C is running. Sounds like you need to drain and flush your radiator if there's rusty crap inside it.
Xvani
Jun 28, 2010 - 12:02 PM
Thanks!
Well aware, but I'm selling the car in a couple of days anyway =)
How do I check the radiator coolant level? (middle one - not overflow)
blu94gt
Jun 28, 2010 - 4:47 PM
QUOTE (Xvani @ Jun 28, 2010 - 12:02 PM)
Thanks!
When it's full, it's full. There's no level, it should just be filled to the top with coolant and distilled water.
nics
Jun 28, 2010 - 5:12 PM
