I replaced wires, plugs, distributor, rotor, fuel filter, tested the fuel pump by bridging the terminals in the diagnostic port, i heard it fine. There was no error code when i bridged the te1 and e1 terminal. Car stuttered and died last night, would not start again until this morning...then i went to buy new plug wires, came back installed them and the car would not restart. I've changed everything aside from the fuel pump. When the car is idling(when it was running) it stutters barely, but when you give it half or full throttle it will kill the engine if you do not let up. It also seems to be backfiring through the intake. Any thoughts are appreciated. One more thing is i havent checked the fuel injectors. ONE more thing, i was browsing and saw a post about an ignition coil causing somewhat similar problems(aside from stutter) maybe that as well???
lewlpop
Kansas City's broke down celica crew WOOT!!!
