QUOTE (QuadCannons @ Jul 5, 2010 - 12:00 PM)
Thanks for pointing out the throttle body.
Are you saying that with those short wrenches, you were able to loosen the EGR valve without having to remove the throttle body?
Just remove the throttle body, its 2 bolts and 2 nuts. It will save you a bit of headache.
Its still a small space to work in, regardless of the shortness of the wrench. If you are already have trouble torguing it off, a smaller wrench is going to make it even harder. Your going to need leverage to get that beast off.
