QUOTE (viruz_one @ Jul 9, 2010 - 1:54 AM)
Well as title says, I need to adjust my clutch pedal. It has way too much travel, i have to floor it order to be able to change gears, on top of that sometimes I dont get it in enough and it starts to grind gears as i switch between them. I thought it had a clutch cable but i guess its a hydualic set up. Do I need to change the fluid and if so, how do i do it. I've always had clutch cable trannies. Any help appreciated.
sounds like you are going to be needing to replace the slave cylinder ... which is what moves the clutch fork inside your transmission really easy to replace and if you ever bleed brakes before you may want to try just to bleed the clutch buy pumping pedal few times and have someone else loosen the bleeder screw on your slave cylinder ..... same concept as bleeding brakes.. if you need more of an explanation let me know and i will tell you ... hope it just needed bleed as you may have air in the lines ....
