PolliS_5S-FE
Jul 9, 2010 - 11:04 PM
Hi guys, after driving for a bit today i stopped at the local autoshop for about 5 min then when i went to leave the car wouldnt start. the engine would turn over but not fire (didnt even work jumpstarting it. the exhaust made noise while rolling but there were no rev's).. then, after about 20 minutes of letting it sit for a bit it started with no problem.. then again when i got home it wouldnt start.. any idea's???? would be much appreciated
Johnnyny
Jul 10, 2010 - 3:11 AM
QUOTE (PolliS_5S-FE @ Jul 10, 2010 - 12:04 AM)
did you get any codes?
PolliS_5S-FE
Jul 10, 2010 - 6:25 PM
no cel came up.. im not sure on how to check the codes?
barterj
Jul 11, 2010 - 2:09 PM
Could be a warn out fuel pump
stwin2
Jul 11, 2010 - 7:15 PM
the same thing happend to my st, take ur batt to get load tested.
PolliS_5S-FE
Jul 11, 2010 - 7:48 PM
i had been having some troubles with it clicking but the thing is it wouldnt even roll start.. could that still be battery issue? i was thinking fuel pump maybe but wouldnt that cause it to not start at all? it starts after its been sitting there a bit, it was running fine on Sunday and today..
stwin2
Jul 11, 2010 - 10:45 PM
well when it happend 2 me. it did the same thing 2 me but it wouldent start after it sat for a wile, but the whole making that sound when u try 2 roll start, thats what happend 2 me and it was the batt it was so bad it would not hold any charge at all, it would not roll start and it would run for a few days after i hooked it up to a batt charger. but its just an idea. u dont have to get a new batt just get it tested.
stephen_lee
Jul 11, 2010 - 11:15 PM
were you getting spark?
PolliS_5S-FE
Jul 12, 2010 - 3:41 PM
thanks stwin, definatly something to look in to. everything is getting power tho (can sit there parked for ages with the radio on etc and have it start first time.) update. yesterday while driving home from work, it was running fine and the n i got to a round about after about 20 minutes of driving and the engine seemed to lose all life for a split second after taking off (nice n slow ofcourse) in first and then did a huge lurching bunnyhop, the C.E.L came on and then started to go again..
now, my main engine bearing has needed to be done for a while. Could this be the cause of all or atleast some of the problems..?
oh and yes, as far as i can tell im getting spark
stephen_lee
Jul 13, 2010 - 4:17 PM
main bearing wouldnt cause that. it'd run till it blows up.
sounds like a coil, or loose connection. check your codes. that will point you in the right direction
PolliS_5S-FE
Jul 13, 2010 - 6:35 PM
ive been reading the pdf file for the check engine light in the "faq" section but i cant really make any sense of it.. i still dont know how to check for codes, do i need any special tools...?
PolliS_5S-FE
Jul 14, 2010 - 3:38 PM
could it be my throttle body?
stephen_lee
Jul 14, 2010 - 8:18 PM
no. check your codes. pop open the diagnostic box next to your brake master cly and put a wire between the E and TE1 pins, turn your key on(dont start) and count the flashes. digit one will flash, short pause, digit two, medium pause, digit one of next code, short pause, digit two of 2nd code, long pause...etc no codes will be continuous flashing.
PolliS_5S-FE
Jul 14, 2010 - 9:41 PM
ok thanks, ill do that tonight, after my 1 hour walk home from work..
PolliS_5S-FE
Jul 15, 2010 - 3:53 AM
okay, so i checked and theres no codes coming up. its just flashing continuously. really not sure what to do now exept trouble shoot.. :s
stephen_lee
Jul 15, 2010 - 12:42 PM
coil
PolliS_5S-FE
Jul 15, 2010 - 4:22 PM
okie dokie, ill look into doing that this weekend, is there a write up on how to change the coil?? ive gotten as far as the rotor but not sure where/how to change the coil... i dont need to buy a whole dizzy do i??
