m2736185
Jul 11, 2010 - 12:26 PM
I was replacing the head gasket on car...I had the engine in TDC position then I accidently turned the the crank and the intake cam...and the exhaust cam stayed in the same position so now the timing is all f'd up...How can I fix this?
Jul 11, 2010 - 3:34 PM
what engine? there should be timing marks on the head to line up the cams. set the engine to TDC and then line up the cams
