PolliS_5S-FE
Jul 15, 2010 - 6:09 PM
title says it.
Also if i can change it will i need to remove the whole dizzy to do it?
is there a write up? Or even a quick how to would be much appreciated.
Thanks,
Paul
stwin2
Jul 15, 2010 - 6:23 PM
i think you have to replace the whole distributer
SleekCelica
Jul 15, 2010 - 7:03 PM
You have to remove the dizzy, but you don't have to replace it. when you take the cap off, you'll see the ignition coil. There will be 2 nuts holding the wires on, and 4 phillips head screws on the bottom holding the coil to the distributor(you can't access those screws with the distributor on, that's why you need to take it off) and then boom, the ignition coil comes right out. I've got a spare coil if yours is fed speced.
PolliS_5S-FE
Jul 15, 2010 - 7:26 PM
oh good. Really glad i dont need to get a whole new dizzy as i just replaced the cap and the rotor 3 days ago. Ill have to check what type is needed and see how much they are around here as im in Nz lol. Thanks Sleek, thats exactly what i was looking for
one quick question, ive noticed alot of oil in the dizzy, on the bottom mainly.. when i take it off will i need to replace the engine oil?
stephen_lee
Jul 15, 2010 - 7:36 PM
no, but replace the oil seal
PolliS_5S-FE
Jul 15, 2010 - 7:41 PM
is that the distributor gasket?
stephen_lee
Jul 15, 2010 - 7:49 PM
no. its probly called oil seal, or oring... diff from the gasket
PolliS_5S-FE
Jul 15, 2010 - 8:06 PM
ok, thanks for all the help
SleekCelica
Jul 15, 2010 - 10:30 PM
It's an O-ring on the distributor shaft(on the side that connects with the camshaft). You can't miss it.
