Full Version: driveshaft
pipes
hey just wondering if anyone knew if the 5th gen drive shaft center bearing is the same as the st205 one? or can a st185 driveshaft fit in a 205? or if anyone has the veterbearings or driveshaft for sale for an st205
Culpable04
the bearings are different, the ST185 uses the same bearing on both places ( same part number ) the ST205 has 2 different part numbers for the 2 bearings, ( shaft uses 2 bearing each bearing has a unique part number )
these are the part numbers for the ST205 bearings
37230 BEARING ASSY, CENTER SUPPORT, NO.1
37230-20150 ST205 (02/1994 - 09/1994) 1 $235.84
37230-20200 ST205 (10/1994 - 07/1999) 1 $193.62
37230J BEARING ASSY, CENTER SUPPORT, NO.2
37230-20160 ST205 (02/1994 - 09/1994) 1 $193.55
37230-20210 ST205 (10/1994 - 07/1999) 1 $193.62
I tried a cross reference and they are not used on any other toyota.
if the bearing is all you need, I'd advise you to take them off, and find your local Kaman industries store
CLICK HERE !
they can get you a replacement for that bearing, but they'd need to see it to get the bearing number.
it'll be a lot cheaper than buying a whole new shaft that may need new bearings anyways.
pipes
the bearing is a rubber insulated piece culp check pic for reference http://cgi.ebay.co.uk/TOYOTA-CELICA-GT4-ST...=item3a5b6b82ac
easternpiro1
having problems with the AWD system? what happened? or are you modifying so it can handle planned extra power?
And btw... WTF is up with the golf club ads? thats the 2nd post ive seen back to back!!
pipes
QUOTE (easternpiro1 @ Nov 12, 2010 - 1:41 AM) *
i wouldnt say problems....but those bushings are getting worn.......what golf ads?
easternpiro1
QUOTE (pipes @ Nov 14, 2010 - 11:17 AM) *
some bot... its been poppin up everywhere. guess it got cleaned. but good luck with the bushings! biggrin.gif
