Full Version: Cold Start Question.....
Chockomon
Hey guys! First off thanks for all your help in diagnosing my girl's car. Got it running now and runs great! I have another issue/question regarding cold temp starting. Since it has been getting colder out here in NJ, I've noticed that on first starting the car after it has been sitting for a while, the engine doesn't rev to about 1500 as I've seen it done in other Toyotas. Is this normal? If not, does that mean the cold start valve or ISV has gone bad? Any help would be appreciated!! Thanks!
the engine doesnt rev? you cant get the the RPMs over 1500? or when you start the car, it idles at 1500?
4-eyed-freek
i had some really bad cold start problemes about a month ago, my dad told me to go and buy some heat and put it in. so i did and everything went back to normal. very good stuff!!
AlyssaGZE
QUOTE (Smaay @ Dec 12, 2010 - 3:12 PM) *
I'm pretty sure he means that the car won't idle at 1,500rpms like it is supposed to do during a cold start.
Chockomon
QUOTE (AlyssaGZE @ Dec 12, 2010 - 7:09 PM) *
Yes, what she said. Searching on the forums led me to the IAC. I'm going to try to clean it out this week. Is there anything else that could cause this symptom?
engine coolant temp sensor is a common culprit for these problems.
4-eyed-freek
i had the same problem, when i started the car it wouldnt even want to idle at 1000rpm. so i cleaned the throtal body ..iac(good luck getting the screws off if you dont have pb blaster or something) and added some heat. work great now.
