I just noticed i never started a build thread here...lol...so here goes!
Starting from 1/1/11 (if you want to see from start to finish check it out here http://www.alltrac.net/phpBB2/viewtopic.php?f=44&t=22608 engine built and in the car already
ENGINE
3sgte bored 20 over
CP 9:0/1 pistons
Eagle H beam rods & ARP bolts
polished and balenced 3sgte crank
ACL race bearing (rods and main)
HKS GT3040 turbo (powdercaoted Purple metalic)
3" SS V-band conversion
SS ramhorn ex manifold
Tial 38mm ex wastegate
custom SS down pipe
Finadanza flywheel
6 puck clutch
new OEM bottom end gasket kit
Powdercoated Purple metalic shaved OEM valve cover
HEAD
mild port and polish
Engle valve springs
new OEM valve seals
HKS 272 cams
HKS ajustable cams
HKS kevlar timing belt
Cometic head gasket
RMR intake maini
KO Racing phenolic spacer(TVIS deleted)
BBK 70mm throttle body
new OEM top end gasket kit
new OEM water pump
ATS high volume oil pump
new OEM belt tensioner
new OEM tensioner pulleys
ARP head studs
ARP flywheel bolts
FUEL
Speed-Source top feed fuel rail
Presision 880 top feed injectors
Aeromotive FPR
Walboro 255 in tank fuel pump
cusom SS fuel lines
new OEM injector spacers & seals
ELECTRONICS
AEM EMS
HKS turbo timer
Inovative LC-1 wideband O2
Eclipse 7" double din DVD/CD
Rockford Fosgate 500 RMS amp
custom 12" sub enclosure (made by me) with MA Audio 12" XL 700 RMS dual coil sub
INTERIOR
Sparco racing seats
Sparco seat mounts (side mount)
KYO seat brackets
Sparco harnesses
Sparco Racer 2 steering wheel
NRG quick release mount
WHEELS & TIRES
STREET
Axis Decades 18x8.5 front and 18x9.5 rear
Continetal contacts 225/35/18 front and 235/30/18 rear
DRAG
Rota Revs 17x8
Bridgestone Potenzas 225/45/17
1" spacer in the rear
SUSPENSION
K-Sport coilovers
MISC
CS/RC front bumper
custom 3" FMIC and piping
custom 4" intake
Samco radiator hoses
Cusco oil catch cam
custom aluminum overflow (made by me)
Speed-Source poly motor and tranny mounts
Speed-Source SS clutch line
2's R us valve cover bolts Hallman maual boost controler
MSD blaster coil
MSD plug wires
NGK one step colder plugs
Goodridge SS brake lines
ABS delete
FUTURE PLANS
Willwood BBK
St205 rear brakes
St205 rear LSD
Cusco under brace
Cusco rear strut brace
Cusco front strut brace
custom fabbed rollcage
respray Toyota super Red
OEM st185 floor matts
CS/RC hood
CCW Classics custom offset wheels
On to the pics!
Engine painted and assembled
Powdercoated some parts
HKS 272 cams, Engle valve springs and shimless bucket conversion
HKS cam gears installed
Then HKS true timing belt
Findanza flywheel and ARP bolts
st205 tranny mated to engine
Speed-source brass shifter bushings
New OEM coolent bypass hoses (hose from hell)
Engine install
Zaklee corp clear cam gear cover (waited over a year for this!)
RMR intake manifold and BBK TB mock up
That's all for now, update soon! should be done in a month or so
