Mycurse180
Mar 9, 2011 - 10:59 AM
Gonna change my oil soon with spring around the corner, temperatures will be in the 30's-50's still for the next few months. What's the most suitable oil I should go with in my 145k mile 5SFE?
Also, which filters do you guys use?
I was on Jeepforum with my previous Jeep and it was made clear NEVER to use Fram filters as they're made of cardboard!
Mar 9, 2011 - 11:02 AM
OEM filters, and the factory recommended 5-30 oil.
95celgt
Mar 9, 2011 - 11:27 AM
i ALWAYS used fram on my 6gc's, never had a problem but now i wonder if thats what caused the insufficient lubrication and spun/ejected my rod bearing and blew the rod out of the block....
95wht6gc
Mar 9, 2011 - 1:31 PM
I always use a Mobile 1 filter and Mobile 1 5w30 oil
SupraKid
Mar 9, 2011 - 1:36 PM
Ive heard nothing but bad things about fram filters, i don't ever use them. I do have a 7a but i use 10-30 mobile 1 synthetic and a mobile 1 filter
4-eyed-freek
Mar 9, 2011 - 1:38 PM
i used k&n oil filter(switched to oem though) and royal purple 5w-30. i have 355k on my 5s
Mar 9, 2011 - 1:39 PM
FRAM = Crap! if you google Fram filters you will find a site that shows how poorly they are made and they come apart. when the paper in teh filter comes apart is goes through your system and yes spins bearings or cloggs passages.
use OEM filters YZZ-F1 i believe is the filter used on both teh 5S and 7A now.
samir0189
Mar 9, 2011 - 1:42 PM
Well, I'll be the black sheep.
I use fram filters. The Xtended guard ones. I change my oil every 7,000 mi, and sometimes 8 or 9,000 pending when I get the time. I have absolutely no problem with them, they seem fine. The oil stays clean for the entire duration, and the filter has an anti-drain back valve.
And I use Mobil 1 synthetic 10-40 or 15-50.
NYp8tBaller07
Mar 9, 2011 - 1:53 PM
I use Fram High mileage oil filters and Valvoline full synthetic, mind you most oil in the US come from like 2 places and companies just put in their additives and there ya go, different brand.
Mycurse180
Mar 9, 2011 - 5:06 PM
You guys need to stop using Fram oil filters unless you want real problems...
cyberblader1130
Mar 9, 2011 - 5:51 PM
10w30 Mobil 1 Syntec + OEM filter.
NYp8tBaller07
Mar 9, 2011 - 6:19 PM
Ive been doimg alot of research on oil filters and it seems mobile1 is very good as well as a few others, as far as oil goes I am still working on that
azian_advanced
Mar 9, 2011 - 6:39 PM
i'm using royal purple 5w-30 now but my next oil change i'm going with 10w30 when the weather warms up. also i used to buy trd oil filters until they became discontinued last year so now i'm using fram xtragard or whatever it's called. i forgot about the negative reviews about fram until this thread popped up.. i'll be using oem from now on.
808celica
Mar 9, 2011 - 6:49 PM
Mobil Uno products
stephen_lee
Mar 9, 2011 - 7:51 PM
mobile 1 10-30 full synthetic for high mileage
OEM filter F1, the larger 4 cyl filter
captb
Mar 9, 2011 - 11:38 PM
Never had problems with fram. Replace it with every oil change. Use mobil 1 synthetic oil.
blu94gt
Mar 10, 2011 - 2:15 AM
Valvoline High-Mileage synthetic 5w30 oil
Supertech (walmart) oil filters
Used to buy Wix filters, but had just as good of luck with the cheap ones at Walmart, read somewhere that they are just rebranded filters and are pretty decent. Once spring really sets in going to change to 10w30 oil. Wouldn't waste the money on Mobil1 since the 5sfe isn't a performance motor.
stephen_lee
Mar 10, 2011 - 12:44 PM
i use mobil1 as i never remember to change the oil on time....
Mar 10, 2011 - 5:31 PM
I just use Castrol GTX in the Celica, and an STP filter. Fram scares me, but Valvoline scares me more. I've seen a study done with ball bearings, wire brushes, and different brands of oil and Valvoline by far performed the worst.
trdproven
Mar 10, 2011 - 5:42 PM
Isn't there a difference with what type of oil you use is dependant upon the mileage or the climate?
95CelicaST
Mar 10, 2011 - 5:47 PM
Wix filter and Castrol Syntec 10w30 because it doesn't get cold enough to need 5w30.
