QUOTE (trdproven @ Jan 13, 2012 - 2:28 AM)
intakes made for the ST and GT are the same thing, whether the pipe is the same size as the TB it will work. if its bigger you just get a proper coupler, which is the reducer mentioned above. in reality, any intake will work as long as you can get it to mount to the TB, have the pipe clear obstruction, and still be able to plug in the MAP. but of course youd want to maximize where the filter is so that air goes to it effectively.
yeah i was just wondering what should i do with the hole that's suppose to connect to the breather tube on the 5sfe motor since i have a 7afe. But i read some articles and it said that a drop in filter works just as good as a short ram so imma grab a kn&n filter instead to save some money. thanks though
