QUOTE (hjesse11 @ Mar 16, 2012 - 7:47 PM)
Cost is an issue right now, if the head is cracked then i will be getting a new engine. If i can find a 2.0 for relatively same price as a 2.2 then i wanna do the swap. Whats the difference between the E56 and E54??
The E56 has a LSD in the differential. (Limited Slip Differential).
Are there any pins that need to be swapped when moving from the 2.2L 5SFE to the 2.0L 3SGE?
I have the ECU, Harness and Fuse box out of a ST202.
