UVZ164
Mar 24, 2012 - 9:39 PM
Hey guys,
Looking at expanding my tool collection with either one of these two.
The leak down test provides more comprehensive results as to where leaks are and exact percentages of cylinder leakage.
But the compression test results seem to be what everyone uses in terms of a PSI number.
My question is if i use the theoretical value of compression provided by the BGB which is 178 PSI (5s-fe engine) and i use the leak down tester and get a cylinder leakage of 10% can i just deduct 10% from that 178 PSI and get 160.2 PSI compression?
If that way works i guess ill get the leak down test if not i need some opinions on what to get.
Thanks,
Reece
Syaoran
Mar 25, 2012 - 3:57 PM
Compression testers are cheaper than Leakdown testers.
You should get a leakdown tester, since it will tell you exactly what is wrong.
Compression testers are all different, and one may read 170psi and the other 180psi. All you need to know from a compression tester is that all values are within a certain range of each other (+/- 5% IIRC), not a specific value.
UVZ164
Mar 25, 2012 - 5:17 PM
Ok, well if the actual number doesnt really matter i guess ill go with a leak down tester. Thanks
Spider77
Mar 25, 2012 - 6:03 PM
Compression testers are just overall engine health. Where as a leakdown tester should let you know how much and from where your loosing compression. If your just looking for PSI range and ease of use, get a compression tester.
Syaoran
Mar 25, 2012 - 9:51 PM
QUOTE (Spider77 @ Mar 25, 2012 - 7:03 PM)
Yes, I forgot about that detail... Compression testers are very straightforward and only require your remove spark plugs, whereas the leakdown testers are a bit more complicated.
Mar 26, 2012 - 9:24 AM
the leakdown will tell you if its in your rings or valves where you are losing compression. I suggest just getting a compression tester. if you have bad compression, the engine is gonna need to be removed anyways.
toyotatech3
Mar 28, 2012 - 3:42 PM
QUOTE (Smaay @ Mar 26, 2012 - 3:24 PM)
i agree with this. plus you can use a couple drops of oil to determine valves or rings.
UVZ164
Mar 28, 2012 - 3:47 PM
Ok means i wont need to borrow a compressor when i wanna use it too. Thanks
