ILoveMySilly97
Mar 27, 2012 - 10:38 PM
I just replaced my vehicle speed sensor today and test drive it. It's running perfectly fine but the thing is it didn't change at all. The speedo and odo still doesn't work. The replacement part was made by Denso. What else can be the problem because everything was done correctly.
KAOS
Mar 27, 2012 - 10:55 PM
If the odometer & the speedometer aren't working and you've replaced the speed sensor - have you tried pulling out the gauge cluster and ensuring everything is tightly plugged in on the back of it?
trdproven
Mar 27, 2012 - 11:07 PM
check gauge cluster, film contacts might not be touching, are dirty, messed up, or the wire all the way is just messed up. Easy test is look at it and determine if its still good replug it in tight and test. or get another cluster and test. then just test everything else after.
Rusty
Mar 27, 2012 - 11:28 PM
