Help
Search
Members
Calendar
Full Version:
95 Celica Transmission Fluid / Differential
6th Generation Celica
Engine/Transmission/Maintenance
fyremaster
Apr 20, 2012 - 9:02 PM
Hi,
I want (desperatly need) to change the transmission/differential oil in my manual transmission Celica.
Can anyone tell me if these oils are combined in the transmission drain/fill or if there is a seperate drain/fill plug for each?
Thanks much!
Apr 20, 2012 - 9:25 PM
Separate plugs. The fill plug is on the front of the trans towards the radiator, the drain plug is under the trans facing the driver side wheel.
fyremaster
Apr 20, 2012 - 9:58 PM
Thanks Richee. That's not quite what I meant. Is there a seperate drain/fill plug for the transmission and differential? (4 plugs? or 2?)
Apr 20, 2012 - 10:05 PM
Ah, gotcha. I read in a hurry earlier. I was wondering why you would ask if there were separate plugs
No, there's just two plugs.
fyremaster
Apr 20, 2012 - 10:09 PM
Thanks Richee!
can you confirm it takes 75w90 gear oil? That is what I am planning on using but want to confirm that is correct.
vile_v
Apr 20, 2012 - 11:28 PM
QUOTE (fyremaster @ Apr 20, 2012 - 8:09 PM)
Thanks Richee!
yes it does, its takes about 2.7 quarts.
The thing is you really don't have to measure, just fill from the fill plug until the fluid starts to leak out. This is how you know its full.
Special_Edy
Apr 21, 2012 - 7:20 AM
Make sure not to get differential fluid. And fill the tranny on a level surface
click here
Invision Power Board © 2001-2024
Invision Power Services, Inc.
