(1) Upper timing belt cover - FOUND
(2) The alternator tensioner assembly seems to be missing from my engine - this is the 12mm bolt that will tighten the acc belt
(3) *stab in the dark here* - TRD Replica Wing (Hatchback)
(4) Driverside Projector with NO broken tabs. (preferably just the housing, so if you have a wrecked one with tabs intact - I'll take it!!)
I'm sure I will need more as the build progresses, so I will add to this list later, but these are the main ones for now.
Thank you!
Shipped to T4B 2V4 Alberta.
