QUOTE (Box @ Apr 27, 2012 - 8:41 PM)
Very cool indeed. The only engine I've ever rebuilt was an old Cadillac OHV V8, that was easy. Today's engines, I'd be lost on setting the timing. DOHC I4 wouldn't be that bad, but DOHC V engines look like a total nightmare. 4 cams and crank I have to get in time with each other, that and with most if you get it off you snap the valves... Why I let my 3000GT go when it needed a rebuild...
Not as bad as you think the timing markes make it all pretty much fool proof. (still not to be taken lightly) You probably noticed he spun the crankshaft a few times throuout the process to make sure everything is moving smoothly and correctly as a test before cranking. I rememeber when i was in the T ten program we were assembling 5S engines in about an hour. of course it helps being at a toyota institute with everything needed and ready to go right their. I wish I had my celi then would have been perfect building at the school.
