Yesaccelica
Apr 29, 2012 - 2:18 PM
I just replaced my clutch so i went for a test drive to see if everything is goooood. The problem is that the clutch is not completely disengaging. Does anyone know maybe what i did wrong or if anyone knows how to fix this PLEASE tell me how.
rave2n
Apr 29, 2012 - 3:42 PM
as in the pedal doesn't come back up, or it never engages...for instance you hit the gas, RPMs fly up...or does it slip up?
Have you checked your hydros for such clutch line? Did you bleed the slave? Did you check to see if the trannie fork is moving the bearing...?
Start there...
Apr 29, 2012 - 4:48 PM
did you open the system? have someone watch the slave cylinder while you pump the clutch. see how much it moves
Yesaccelica
Apr 29, 2012 - 5:13 PM
I have to start the car in gear and even with the clutch pressed all the way in, it moves forward. I did bleed the slave and the trannie fork is moving the bearing
