hey i've been searching the forum but cant seem to find anything on this wire. im thinking its just a simple ground but want to confirm. and if is just ground im going to replace. the wire seems kinda torn up for some reason and it goes from the block to was seems like the chassis on the passenger side near the abs. i have the wiring diagram but can't figure out which this wire goes with. any help would be much appreciated. (also i see it has a plug in the middle but wondering if i can just replace it with a continues wire i have some 4ga cable i just bought)
its the one im holding
can see it starts on the block behind the hook. then its a lil shredded to a plug and continues to the pass side behind the abs lines it ends.
