Full Version: 94 ST engine conversion kits
Mercedes831
I have a stock 94 Celica ST and I want to give it some more power. I've been looking into converiting the auto tranny to a 5 speed as well as upgrading the 7afe to a larger engine. money isn't really a issue but I'm looking at around $5,000 for the project. does anyone know a kit that works or what size engine would be best? thanks
bccentaur3
If money's no option why a 5k budget? Becuse u are starting with a st chassis you will have to spend a little more for mounts and what not. 3s swap alone you will need around $5k to do it right the first time. Plus u need a s54 trans or a e153, if "money is no issue".
stephen_lee
v6 is a cheaper option as you can buy a donor car locally. look for a manual camryr v6 and theres ur engine and trans, wiring, afm, etc. just will need mounts, axles and shifter cables.
v6 can be done for 2.5-3k
3sgte will take 5k or so
kurt95gt
3vz v6 swap would be cheapest
Just check local junk yards an get a front cut with most of what youll need
Mercedes831
I was more asking about ideas on my car not my budget but thanks for the input. As for your question just because it's not an issue i'm not going to go crazy i was giving an estimate. kthanks
QUOTE (stephen_lee @ May 29, 2012 - 3:07 PM) *
thank you I'll look into it
QUOTE (kurt95gt @ May 29, 2012 - 2:43 PM) *
cant do a 3VZ here in CA, since he has a 94 he has to use a 1MZ. Now for the OP, where in CA are you, im in the middle of a V6 swap right now and i can totally help you do yours.
Mercedes831
QUOTE (Smaay @ May 30, 2012 - 9:29 AM) *
thanks i wouldnt have known that i'm local by santa cruz
Syaoran
v6 gives you a better bang for your buck, stock for stock, compared to a 3sgte swap, and the torque is instantly there... make sure you pair it with a e153!
kurt95gt
I have mine 1mz paired with a s54 an it feels great!
stephen_lee
with an e153 you will get better mpg and have a better power band as it was designed for the v6..
s54 will work but risk breaking it if you launch hard and higher cruising rpms = lower mpgs
