cheela
Aug 6, 2012 - 5:17 PM
my hood latch has always given me trouble. the trouble was that once it was opened it wouldn't close like some members on here talk about. but this time it's the other way around. It's close and i can't get it to open. I pull the hood release on the inside and feel nothing. there's no tension.
Does anyone know how to open the hood? I've looked and there's been no discussion on this. Or a write up of how to take the cable out.
I guess it's good that it's not stuck open but I would like to change my oil soon and other maintenance so the sooner I can get it open the better.
mak5603
Aug 6, 2012 - 6:07 PM
Can you lift it by hand a bit?
One time before i extended my latch I forgot and closed my hood and couldn't get it back open.
I opened it by hand just a little and was able to fit something (possibly some pliers or something, I don't really remember) in and manually unlatch it.
Sorry, if this wasn't much help. I'm sure you have already tried this a million times..
SupraKid
Aug 6, 2012 - 6:29 PM
You can also undo the latch in your cabin and pull the cable and see if its just stretched.
Tigawoods
Aug 6, 2012 - 7:27 PM
its totaled.
blow torch and cut a hole.
cheela
Aug 6, 2012 - 7:30 PM
QUOTE (mak5603 @ Aug 6, 2012 - 6:07 PM)
did it damage the hood? I want to try that but me and my brute force might kill the hood.
QUOTE (SupraKid @ Aug 6, 2012 - 6:29 PM)
probably gonna try that.
QUOTE (Tigawoods @ Aug 6, 2012 - 7:27 PM)
its totaled.
oh god I hope not!!!
QUOTE (njccmd2002 @ Aug 6, 2012 - 7:27 PM)
I guess that would give it some good airflow into the hood.
95CelicaST
Just unbolt the release under the dash and pull the cable.
mak5603
Aug 6, 2012 - 7:36 PM
QUOTE (cheela @ Aug 6, 2012 - 5:30 PM)
Well you can only physically lift it like an inch, then gotta fit something in to unhook the latch. Don't just try and rip it off, haha.
Tigawoods
Aug 6, 2012 - 9:34 PM
QUOTE (mak5603 @ Aug 6, 2012 - 8:36 PM)
Just try and rip it off, haha.
Fixed that for ya
azian_advanced
Aug 6, 2012 - 9:40 PM
remove the front splash guard between the lower rad support and the bottom of the front bumper. then using long pliers and someone with long skinny arms, pull the cable.
Aug 7, 2012 - 8:26 PM
These solutions are all too complicated. Chee, you don't need the hood to open at all. Just flip it over and do everything from underneath.
cheela
Aug 7, 2012 - 11:25 PM
hahaha! I see, I was over thinking this whole time! so simple!
now i just need to enter hulk mode and flip this thing over. thanks Daniel!
Aug 7, 2012 - 11:35 PM
QUOTE (azian_advanced @ Aug 6, 2012 - 9:40 PM)
did you try this, seriously, its the only way
cheela
Aug 8, 2012 - 12:11 AM
not yet but that does seem like the only way to get it open. once i have some down time to mess with it I will.
Aug 8, 2012 - 12:17 AM
actually you have to get down to do it. so you need some down time to get down..
Neon90424
Aug 8, 2012 - 7:31 AM
o.o hammer it to death... go hoodless until CF hood magically appears
NOVAKx17
Aug 11, 2012 - 11:51 PM
i had this happen once.... i used a hack saw when i got the hood pried open an inch and cut the actual U that the hood latch locks onto off and used hood pins from there on out.... alot cheaper than buying a new hood and replacing the cable.... simple and efficient
cheela
Aug 12, 2012 - 12:12 AM
LOL! well, it was actually the easiest thing to do. I didn't even have to take the plastic off the bottom. just reached my hand up from the grill and pulled the cable and POP!
Nihil
Sep 17, 2012 - 8:01 AM
well... happened to me today that the cable snapped
and lucky me, it just so happens that my battery is dead
So now, I can't even drive the car until I get the hood open.... anybody got some ideas?
My first idea was to simply drive the car to toyota so they can get the hood open and replace the cable, but now the car is just sitting there and not going anywhere
Don't want to sound stupid, but is there any way of charging the battery some other way? let's say ciggarete lighter socket or something...
azian_advanced
Sep 17, 2012 - 8:17 AM
push start it.
Nihil
Sep 17, 2012 - 8:53 AM
Ok, I jacked it up, and reached it from below... The cable is ok, but it disconnected/unhinged from the hood latch, what is even more ****ED!
If someone got some advice at this point, it would be greatly appreciated
Nihil
Sep 17, 2012 - 10:50 AM
huh... managed to open the hood
So if anyone else got the same problem someday, access the latch from bellow, it is pretty easy (if you haven't got some intercooler there:D).
Then there is a small opening on the bottom of the latch, where you can reach the mechanism that the cable pulls, best to use some sort of "hook-like" tool, I've sketched this here:
I can't remember the last time I've been so pissed
but everything turned out ok
cheela
Sep 25, 2012 - 8:05 PM
what i ended up doing the second time since the cable got stuck and couldn't yank on it. I just stuck my hand and tools through the grill and up and started unbolting the 3 bolts that hold the latch on. took a bit of finger work but after i got the 3 bolts out I just yanked the WHOLE hood latch to the side and popped it open.
