Jabberwock
Jan 10, 2004 - 12:36 AM
TRD quick shifter seems to be the more popular one but I found TWM short shifter for $140 and was wondering if TRD;s has a significantly better performance.
Which one would you prefer?
PlanetFuzz
Jan 10, 2004 - 12:39 AM
never used TWM...but the TRD quickshifter if phenominal. If I am correct,the TWM is only the shifter and not the entire assembly. I LOVE my quickshifter
BigEdge169
Jan 10, 2004 - 12:47 AM
and the TRD shifter usually comes with a leather TRD shift knob if that means anything to you also
Buggin
Jan 15, 2004 - 6:57 PM
I have the TMW shifter and I don't have any problems with it. I had it installed in my car by myself about two hours after I got it. The throw and height are both a lot shorter and I don't ever grind gears unless my leg gets lazy and I don't push the clutch in enough. And sometimes reverse can be tricky but it was like that before I got the shifter.
Jan 15, 2004 - 7:07 PM
yeh its a good shifter. i like mine. its also shorter then the trd one. so, its up to you, cant go wrong either way.
Jabberwock
Jan 15, 2004 - 9:56 PM
Is it easy to install and is it quicker than the TRD shifter.
The TWM one is shorter but is it quicker.
Jan 15, 2004 - 10:13 PM
the install will take you about the same amount of time for either shifter.
frotou
Jan 16, 2004 - 12:37 PM
I have the twm and it work perfectly
