Jokester
Nov 5, 2012 - 2:09 PM
Have a 95 gt 5sfe. Was wondering if anyone know if it have a coil wire for the distributor?
Cause I'm getting NGK spark plug wires (TE44) for it and those come with a coil wire.
czwalga
Nov 5, 2012 - 3:59 PM
I had a 95 gt, the coil was built into the distributor, so no wire; my 3sge does have a coil wire. Just look at your distributor you should be able to tell easily.
Jokester
Nov 5, 2012 - 4:58 PM
QUOTE (czwalga @ Nov 5, 2012 - 12:59 PM)
Ahh that what I thought when I looked at it. Thank you!
Special_Edy
Nov 6, 2012 - 8:59 AM
I thought the california emissions had a external ignition coil(that is not in the dist) with a seperate coil wire attaching them. Im only 90% sure thats true though, cause I havent seen alot of Cali spec celicas out here.
Nov 6, 2012 - 9:25 AM
I dont remember seeing an external coil on mine. ill take a look on my engine tonight at the distributor and see if it has a 5th wire for a coil. thats the giveaway.
Xander_X
Nov 6, 2012 - 9:44 AM
They changed little things in the 5S back and forth through out the year, hard to say even being Cali Spec. Just look at your dizzy and see if it has only 4 wires coming out or if there's a 5th one coming out of the center and going to a coil that sits above your brake booster. It's really that simple.
rave2n
Nov 6, 2012 - 11:06 AM
My 95 has a coil wire.
Jokester
Nov 6, 2012 - 11:13 AM
hmm...interesting..
I'm pretty sure mine doesn't, but I'll take a pic and post it up later. Thanks guys!
Special_Edy
Nov 6, 2012 - 2:51 PM
Im just aware that Spider77's 94 GT coupe that is cali spec has an external coil with a 5th ignition wire. It caught me off guard when I saw it.
trdproven
Nov 6, 2012 - 5:24 PM
Ahhh ok, I was wondering which celicas had the external coil. Good to know. Nice to run a better ignition set up with that option.
Spider77
Nov 7, 2012 - 7:00 PM
QUOTE (Special_Edy @ Nov 6, 2012 - 2:51 PM)
True, My cali spec (in texas..go figure) has a 5th wire.
Jokester
Nov 7, 2012 - 9:34 PM
So...doesn't appear mine has a 5th. Its a Cali spec, I think?
Sorry, I don't know how to make the pic smaller =/
Xander_X
Nov 8, 2012 - 9:09 AM
Internal coil bud
rave2n
Nov 8, 2012 - 10:46 AM
coil wire to ignitor
Jokester
Nov 8, 2012 - 5:02 PM
K thank guys!
